Velgmaten & Bandenmaten
Hoe zitten de maten van een velg in elkaar?
Ooit zocht ik ze eens (ongeveer) allemaal op voor iemand...
YAMAHA:
Raptor 700, YFZ450, Banshee, Raptor 350
front: AT21x7-10
rear: AT20x10-9
Blaster
front: AT21x7-10
rear: AT21x10-8
Wolverine 450 4x4, Wolverine 350
front: AT23x8-12
rear: AT23x10-12
Grizzly 660 4x4, Kodiak 450 4x4, Big Bear 400 4x4, Bruin 350 4x4
front: AT25x8-12
rear: AT25x10-12
Bruin 250
front: AT22x7-10
rear: AT22x10-10
Warrior 350
front: AT22x7-10
rear: AT22x10-9
SUZUKI:
QuadRacer LT-R450,
front: AT20x7R10
rear: AT18x10R8
QuadSport Z400, QuadSport Z250
front: AT22x7-10
rear: AT20x10-9
KingQuad 700 4x4, TwinPeaks 700 4x4, Vinson 500 4x4, Eiger 400 4x4,
front: AT25x8-12
rear: AT25x10-12
KAWAZAKI:
KFX700
front: AT22x7-10
rear: AT22x11-10
KFX400
front: AT22x7-10
rear: AT20x10-9
Brute Force 650 4x4, Prairie 700 4x4, Prairie 360 4x4
front: AT25x8-12
rear: AT25x10-12
POLARIS:
Outlaw, Predator 500, Trail Blazer 250
front: 21x7-10
rear: 20x10-9
Predator TLD
front: 21x7-10
rear: 20x11-9
Sportman 800 EFI, Sportman 700 EFI, Sportman 700 Twin, Sportman 500 EFI,
front: 26x8R12
rear: 26x11R12
Sportman 500 H.O., Sportman 450, Sportman X2, Sportman 6x6
front: 25x8-12
rear: 25x11-10
Sportman MV7,
front: 25x8-12
rear: 25x10-12
Hawkey 2x4, Hawkey 4x4
front: 22x7-12
rear: 22x10-12
Sawtooth
front: 21x7-10
rear: 21x10-10
Magnum 330 4x4
front: 24x8-12
rear: 24x11-12
Trail Boss 330, Scrambler 500, Trail Blazer 250
front: 23x7-10
rear: 22x11-10
HONDA:
TRX450R, TRX400EX,
front: 22x7-10
rear: 20x10-9
TRX300EX, TRX250EX, FourTrax Recon, FourTrax Recon ES
front: 22x7-10
rear: 22x10-9
FourTrax Rancher
front: 24x8-12
rear: 25x11-10
FourTrax Rancher AT, FourTrax Rancher AT GPScape, FourTrax Rancher ES
front: 24x8-12
rear: 24x10-11
FourTrax Rancher 4x4, FourTrax Rancher 4x4 ES
front: 24x8-12
rear: 24x9-11
FourTrax Rincon, FourTrax Rincon GPScape, FourTrax Foreman, FourTrax Foreman 4x4, FourTrax Foreman 4x4 ES, FourTrax Foreman Rubicon, FourTrax Foreman Rubicon GPScape
front: 25x8-12
rear: 25x10-12
YAMAHA:
front: AT21x7-10
rear: AT20x10-9
Blaster
front: AT21x7-10
rear: AT21x10-8
front: AT23x8-12
rear: AT23x10-12
front: AT25x8-12
rear: AT25x10-12
Bruin 250
front: AT22x7-10
rear: AT22x10-10
Warrior 350
front: AT22x7-10
rear: AT22x10-9
SUZUKI:
QuadRacer LT-R450,
front: AT20x7R10
rear: AT18x10R8
front: AT22x7-10
rear: AT20x10-9
front: AT25x8-12
rear: AT25x10-12
KAWAZAKI:
KFX700
front: AT22x7-10
rear: AT22x11-10
KFX400
front: AT22x7-10
rear: AT20x10-9
front: AT25x8-12
rear: AT25x10-12
POLARIS:
front: 21x7-10
rear: 20x10-9
Predator TLD
front: 21x7-10
rear: 20x11-9
front: 26x8R12
rear: 26x11R12
front: 25x8-12
rear: 25x11-10
Sportman MV7,
front: 25x8-12
rear: 25x10-12
front: 22x7-12
rear: 22x10-12
Sawtooth
front: 21x7-10
rear: 21x10-10
Magnum 330 4x4
front: 24x8-12
rear: 24x11-12
front: 23x7-10
rear: 22x11-10
HONDA:
TRX450R, TRX400EX,
front: 22x7-10
rear: 20x10-9
front: 22x7-10
rear: 22x10-9
FourTrax Rancher
front: 24x8-12
rear: 25x11-10
front: 24x8-12
rear: 24x10-11
front: 24x8-12
rear: 24x9-11
front: 25x8-12
rear: 25x10-12
Hier kun je ze ook bijna allemaal vinden: http://www.rockymountainatv.com/machineSpecs.do
- raptor350
Omdat hier geen info staat over hoe je bandenmaten moet aflezen. Is dit mss zeer handig !
Zodat je kan weten hoe breed en hoe hoog je band is.
hopelijk vinden jullie dit nuttige informatie
Voorbeeld
Op een autoband kan staan: 195/50 R15.
Hierin is:
195 de bandenbreedte in mm.
50 de verhouding van de bandbreedte/bandhoogte in % (in dit voorbeeld 50% van 195 mm).
15 de diameter van een velg in inches.
Extra toevoegingen:
R geeft de bandenopbouw aan. (R = radiaalband)
90 is een indexering voor het draagvermogen van een band. In dit geval kan de band 600 kilo dragen.
H geeft de maximumsnelheid aan van een autoband. (H = 210 km/u)
Overige snelheidssymbolen in km/u:
J=100, K=110, L=120, M=130, N=140, P=150, Q=160, R=170, S=180, T=190, U=200, H=210, V=240, W=270, Y=300, ZR=240+
( dit is wel over auto banden , maar ik vermoed dat dit bij quads juist hetzelfde is ) Verbeter me indien ik fout ben ...
MVG
Voorbeeld
Hierin is:
Extra toevoegingen:
MVG
Owner van yamaha raptor350
Er is een topic op dit forum, met een duidelijke tekening hoe het zit met de steek van een velg.
Na velgmaten bij google ingetypt te hebben kwam ik hier op uit: http://www.gbshop.nl/content/informatie ... gmaten.htm
en als je het niet snapt, kun je google of de zoekfunctie van het forum gebruiken
Suc6,
Suc6,
Re:
Ralph schreef:Hier een uitleg over hoe de maten van een velg in elkaar zitten.
Staat ergens in de velg ook die verdeling? Hoever de velg dus naar binnen of buiten staat t.o.v. het hart van de velg?
Ik wil namelijk andere velgen kopen die niet verder naar binnen mogen staan ivm de uitlaat.
'Onmogelijk' is een mening, geen feit.
Re: Velgmaten & Bandenmaten
hallo, ik ben namelijk sinds een paar weken een trotse vader geworden van een yamaha yfz 450
en ik zou daar baan banden willen opleggen maar vermits ik daar nie echt in zit in quadbanden (straat) zou ik
begot nie weten wa maat ik ter moet gaan opleggen en welk merk.
dus nu is mijn vraag of ik de originele maat het best er trg opleg of een andere maat neem bv: een iets minder hoge band
alle het moet er ook schoon onder staan he qua zicht he
en welk merk he da zou ik ook graag weten wa jullie mij aanraden...
grtzzz.
grtzzz.
yfz 450
als je wil weten wat mooi is quad banden, dan zou je ff in de garage van het forum moeten kijken (heb ik ook gedaan om te beslissen welke accesoires ik op m raptor wilde )
Verder zou je de zoekfunctie ff kunnen gebruiken
Ik heb niet heeel veel verstand van banden....
