Standaard zit een watertemperatuurmeter op de Grizz 700
blokart
Bericht door blokart »
De werking hiervan kan ik niet controleren, misschien iemand onder jullie?
Hierbij de Engelse uitleg:
"You may or may not know this but there is away to check your coolant temp through your pod on our grizzly 700's. Hold down the select and reset button on the pod, Then turn the key on, When the word "diag" comes up you then again hold down the same 2 buttons and it will change to d01. Now use the select button to go to d06. This is your coolant temp in Celsius. To get out of this just turn the key off.I was running my grizz pretty hard in deep sand for about an hour and my temp was 96 Celsius, which is 204.8 in Fahrenheit. Seems a little hot but I was pushing it pretty hard in that sand. Thinking of maybe trying some engine ice or something like that to lower that temp a little. I will also post this link to convert from Celsius to Fahrenheit. Just another neat feature about the grizzly I thought I would share."
AUB
yamahakodiak
Bericht door yamahakodiak »
bedankt voor de info :duimhoog:
yamaha grizzly 700fi
