Forum Update's ! (phpbb-2.0.21)
				Ivoman #7
lees, als je in de chat zit, de help sectie!
- Type '/pm gebruikersnaam', zo stuur je iemand een pm je te vergezellen in de chat
- Zit iemand al in de chat, maar die is niet actief, type dan '/alert gebruikersnaam', zo komt de chat bovenaan de gebruiker z'n scherm.
				Ivoman #7
- Dank topicstarter
In sommige forums kan je een topicstarter bedanken voor zijn/haar geplaatste onderwerp, door een simpele druk op de knop.
In dit topic van Hanzie kan je al eens zien hoe het werkt.
(klik op de '1')
Niet echt een nuttige mod, maar goed.
(klik op de '1')
				Ivoman #7
What has changed in this release?
The changelog (contained within this release) is as follows:
- * [Fix] Prevent login attempts from incrementing for inactive users
 * [Fix] Do not check maximum login attempts on re-authentication to the admin panel - tomknight
 * [Fix] Regenerate session keys on password change
 * [Fix] retrieving category rows in index.php (Bug #90)
 * [Fix] improved index performance by determining the permissions before iterating through all forums (Bug #91)
 * [Fix] Better handling of short usernames within the search (bug #105)
 * [Fix] Send a no-cache header on admin pages as well as normal board pages (Bug #149)
 * [Fix] Apply word censors to the message when quoting it (Bug #405)
 * [Fix] Improved performance of query in admin_groups (Bug #753)
 * [Fix] Workaround for an issue in either PHP or MSSQL resulting in a space being returned instead of an empty string (bug #830)
 * [Fix] Correct use of default_style config value (Bug #861)
 * [Fix] Replace unneeded unset calls in admin_db_utilities.php - vanderaj
 * [Fix] Improved error handling in modcp.php
 * [Fix] Improved handling of forums to which the user does not have any explicit permissions - vanderaj
 * [Fix] Assorted fixes and cleanup of admin_ranks.php, now requires confirmation of deletions
 * [Fix] Assorted fixes and cleanup of admin_words.php, now requires confirmation of deletions
 * [Fix] Addition and editing of smilies can no longer be performed via GET, now requires confirmation of deletions
 * [Fix] Escape group names in admin_groups.php
 * [Sec] Replace strip_tags with htmlspecialchars in private message subject
 * [Sec] Some changes to HTML handling if enabled
 * [Sec] Escape any special characters in reverse dns - Anthrax101
 * [Sec] Typecast poll id values - Anthrax101
 * [Sec] Added configurable search flood control to reduce the effect of DoS style attacks
 * [Sec] Changed the way we create "random" values for use as keys - chinchilla/Anthrax101
 * [Sec] Enabled Visual Confirmation by default
 * [Change] Changed handling of the case where a selected style doesn't exist in the database
 * [Change] Changed handling of topic pruning to improve performance
 * [Change] Changed default forum permissions to only allow registered users to post in new forums
				Ivoman #7
- Forum Banners
Eindelijk is het zover.
De forum sponsors worden vertoond met winkel-banner bovenaan het forum.
Door op de banner te klikken wordt je naar de website gelinkt.
PS:
Ik heb er menig uur ingestoken. Vooral de banners zelf maken heeft veel tijd ingenomen. De mod installeren die telkens een andere banner toont als de pagina hernieuwd wordt was maar een klein uurtje werk. Maar al in totaal kan je wel op een 30uur rekenen.
Ik wil maar zeggen dat ik hoop dat de fondsen die de sponsoring opbrengt maar als goede huisvader besteed worden.
Want ik doe dit volledig op vrijwillige basis. Een tegemoetkoming is natuurlijk altijd welkom...
PS:
				No Limit W-tec
Ik zie niets van sponsorbalk, zijn er nog die niets zien ?
Misschien onderdrukt door een of andere beveiliging als Norton of dergelijke ?
