suzuki 450r
wantjes #9
Sharky #3
Naar het schijnt zou hij 3 inch breder zijn dan de z400Ivoman schreef:Aah! Had mij altijd al afgevraagd waarom ze quads standaard zo 'small' maken.No Limit YFZ schreef:Persoonlijk vind ik niet dat de quad 50 inch/130 cm breed lijkt. Denk ook niet dat men op de markt zou komen met een quad die zo breed staat want dan gaan de GNCC cross country rijders klagen dat ze niet tussen de bomen kunnen.
Klinkt logisch.
Maar vannacht zouden we alles met zekerheid weten, dan zou men de voorstelling doen...
Fré
ja, vantweekend wast dealer show, en nu zijn er weer meer pics en specs!:
Suzuki created the high-performance sport quad market in 1985 with the QuadRacer LT250R. Since then, the ATV market and the state of Suzuki performance technology has changed greatly. And 20 years later, the QuadRacer is back. Having built a brand name around the manufacture of high-performance motorcycles and new award-winning ATVs, Suzuki is ready to deliver the finest high-performance sport ATV available.
And not a moment too soon. As racing becomes more and more expensive for ATV enthusiasts, Suzuki delivers race-ready hardware at a price that can’t be beat. The 2006 Suzuki LT-R450 QuadRacer is designed for race-ready performance – winning performance – with little or no modifications necessary.
The new quad features a 450cc four-stroke engine with Suzuki electronic fuel injection, and it’s based on the championship-winning RM-Z450 MX bike’s engine. It’s equipped with a track-holding wide stance and long-travel, competition-ready suspension that’s fully adjustable.
A lightweight and strong steel swingarm, center exhaust, titanium valves, new dry sump system, magnesium covers, aluminum front hubs, electric start, removable headlight, and liquid cooling – just a few of the strong features that will make the LT-R450 the class leader of high-performance sport quads.
ENGINE
Engine Type 450cc,Single-cylinder, DOHC 4-valve, liquid-cooled
Bore x Stroke 95.5 X 62.8 mm
Compression Ratio 11.7:1
Carburetion Fuel injection system
Ignition N/A
Starting System Electric
Lubrication System Dry sump
Transmission 5-speed constant mesh
SUSPENSION
Front Dual A-arm independent suspension, with 10.0 inches travel, fully adjustable piggy-back reservoir
Rear Swingarm with single shock suspension, with 10.9 inches travel, fully adjustable piggy-back reservoir
BRAKES
Front Dual Hydraulic Disc, Twin Piston
Rear Hydraulic Disc, Twin Piston
TIRES
Front AT 20x10 Radial Dunlop KT381
Rear AT 18x10-8 Radial Dunlop KT385
DIMENSIONS
Front Track 41.2"
Rear Track 38.8"
Seat Height N/A
Wheel Base 50.6"
Ground Clearance N/A
Dry Weight 368 Lbs
Fuel Capacity N/A
ENGINE
Ignition N/A
SUSPENSION
BRAKES
TIRES
DIMENSIONS
Front Track 41.2"
Rear Track 38.8"
Seat Height N/A
Wheel Base 50.6"
Dry Weight 368 Lbs
Fuel Capacity N/A
peet #77
hoeveel pk heeft hij die quad
wantjes #9
Fré
www.google.bewantjes schreef:en het gewicht!?banshee--lover schreef:kan iemand de afmetingen in cm of meter ofzetten !
dan krijgd ge een duidelijk beeld hoe breed hij is... ziet er toch al aardig breed uit !
greeetz
ge krijgt een spekke als ge vindt hoe ge al die informatie direct kunt terugvinden
peet #77
die is gewoon super die uitlaat de maxDavid, kfx 700 schreef:Die yoshi is prachtig
