Polaris Predator Tuning
Geplaatst: ma 17 apr, 2006 16:23
door adlyRocky
Nu ik een polaris Predator heb aangeschafd zal het niet lang duren voor de extra nodige pk`s
Om het net wat leuker te maken dan het al is...
Omdat er nog geen topic was zet hier de koopjes in voor de predator...
Performance kit Predator 550 cc ombouw.
550 Big Bore Kit
We resleeve your cylinder and bore it out to 105 MM. A forged big bore piston and gaskets are included. Expect 5 HP more on top end a strong increase in midrange torque. 550 Big Bore Kit ATP12993 $530
550 Piston ATA30095 $175
550 BBK Sleeve ATP70000 $88
550 BBK Gasket Kit ATAC7996 $59
Catalog Page-5 / Aftermarket Performance Polaris Predator Power Products
Mega Power Pipe
This is our most powerfull Predator pipe (8 HP over stock)! This design does everything right. The tapered megaphone section roost on the top end, and the larger muffler volume delivers more torque and arm stretching acceleration. The 4" aluminum body accommodates generous fiber packing and brings the sound down to 96 dBA. You are sound legal and ready to perform on racetrack and trail. Direct bolt on 4" Supertrapp spark arrestor kit available. Mega Power Pipe PAT80000 $319
Spark Arrestor Kit PAT50100 $69
Jet Kit ACA30040 $59.95
Race Filter Kit
Eliminate the stock airbox and release more power! Complete kit includes a Maxi-Flow racing filter with outerwear mounted directly on the carb, oil breather foam filter, aluminum mud guard and a carburetor jet kit. Filter Kit ATA30098 $129
Forged Clutch Basket
Wiseco is focusing it's superior forging technology on making the strongest clutch basket on the market. The aircraft quality forging is precision machined on the latest CCM equipment. A must for pro-level moto-cross and enduro racing. Clutch Basket ATCWPP3020 $230
Edelbrock Carb
The Edelbrock Performer flatslide carb shows dyno increases of as much as 4 HP. With the adjustable accelerator pump you get quick throttle response and top end calibration that extends your powerband. Race tested by national riders, this carb already has a winning record. Tunes easily from the outside. Extra tuning parts included. Edelbrock Carb ACA31960 $549
Vortex Ignition Box
This complete ignition box gives you a choice between 10 diferent ignition curves and 4 different rev limits (8900, 9150, 9450,10,100). Stock rev limit is 8600. Pick between power, traction and standard maps to get the best combination for the days activities at the race track or on the trail. A handle bar switch lets you select between your two best setups on the run. Vortex Ignition Box ~ 02-04 ATA VT-6500 $399
Vortex Ignition Box ~ 2005 ATA VT-6505 $399
Head Porting
Maximize the performance of your Predator. Get your cylinder head ported by our professional craftsmen. The passages are enlarged and polished, the valve pockets in the combustion chamber reworked for better flow and the valve seats redressed. Extra charge for cleaning, removal and re-installing of the valves. Head Porting ATP12994 $299
Cleaning / Valve Removal ATP39001 $40
High Comp Piston
The Predator 12.5:1 forged high performance piston mounts directly in the stock bore. Expect a 3 HP increase with much improved midrange torque. Cometic gasket kit available. Hi Comp Piston ATAP9920 $149
Cometic Gasket Kit ATAC7995 $57
High Lift Cam
These cams open your valves further for better airflow. Experience a power increase in both midrange and on top end without loss of bottom end torque. Should be used with stiffer valve springs if rev limiter is set for over 10,000 RPM. Intake Camshaft ATA30099 $395
Exhaust Camshaft ATA30100 $425
Core Exhange, ea.shaft ATA30101 $70
High Rev Spring Kit ATA31002 $99
NEW! Polaris Predator 600cc Big Bore / Stroker Mod
Big Boomer Kit - Hungry for maximum power for your Polaris Predator? Falicon can modify your crank and cylinder for impressive power gains.
First, we bore your cylinder 2mm larger. Next, we stroke your crank and add a Falicon Knife® Rod. We supply a special piston kit designed to handle the power of this huge engine. The end result is an engine that is almost 25% larger than stock with impressive power gains
600cc Big Bore / Stroker Crank Mod Kit
#SBK-P600C
Includes:
Long-Rod Stroker Modifications -73.5mm
Falicon Knife Rod
Big Bore Modification - 102mm
Piston Kit (102mm) Stroker Compression
You must send us your Crank and Cylinder for this modification. You cannot use a stock-style piston with this kit, due to changes in the wristpin size and compression height.
$1906
AC Racing
Predator Pro Peg (04-5650)
$309.95 Pair
IMS
Predator 500 Stainless Steel Foot peg w/kick up
AC Racing Predator Grab Bar
$54.95
A-Arms - Predator $660.00
The Predator A-Arms are 2" wider and 0" forward. They have adjustable caster but use the stock ball joints so there is no adjustable camber. Each set uses the stock length shocks.
Geplaatst: wo 19 apr, 2006 20:59
door epix no-fear
kijk eens op www.rathracing.com de polaris specialist
