Pagina 1 van 4
KTM 450/525 2008
Geplaatst: zo 27 mei, 2007 18:03
door brutus32
http://pinitmotorsportsmc.com/
CHASSIS
1 Advanced engineering produced a strong light weight ATV, weight 356 lbs.
2 Frame has many hrs of durability testing with no breakage or signs of fatigue.
3 Frame design offers easy service and a 450 or 525 bolt in engine option.
4 Swing arm shaft and countershaft position enhance handling and suspension.
5 Durable tested tough light weight skid plates on frame and swing arm.
6 Rear axle cam type bearing carrier has quality tapered bearings for long life
7 Axle cam type bearing carrier and swing arm offer quick and easy chain adj.
8 Rear axle bearing carrier comes with easy access grease fitting for lubrication.
9 Rear axle is very strong with an axle retainer nut system that holds position
1 Chassis and frame designed with light weight secured fastener nuts.
2 Removable rear sub-frame is strong and light weight with built in flag holder.
3 Light weight front uprights reduce camber change during jounce & rebound.
4 Common Industry wheel bolt patterns reduce rider transition cost to KTM
5 Maxxis race ready tires set a new standard for production performance level.
6 Douglas wheels with a new strong light weight design raise performance level
7 Self locking rear axle nuts allow quick hub and tire changes for GNCC racing.
8 Well designed and tested wheel base and chassis width make ATV race ready.
9 Well designed suspension and chassis allow ATV ride height to easily change.
10 Quality 520 O-ring chain used for long life and reduced adjustment intervals.
1 Swing arm chain guards and built in chain guide well designed and durable.
SUSPENSION
1 Ohlins dual rate springs with adjustable cross over on the front.
2 Front shocks have adjustable preload, compression and rebound adj.
3 Front upper control arms mount with adjustable Hym.joint bearings.
4 Front lower control arms mount with replaceable needle bearings
5 All control arms offer serviceable ball joints for reduced service cost
6 The upper control arms offer complete adj. of camber and caster.
7 Well engineered front and rear suspension offer 11 inches of wheel travel
8 Ohlins PDS reservoir rear shock with preload, comp. & rebound ADJ
9 Ohlins PDS system allows a no link design for reduced weight & maintenance
1 Ohlins PDS stands for progressive damping systems (dual piston design)
2 No link suspension adds ground clearance and makes rear shock change quick
STEERING
1 Steering stem and frame designed to bolt on advanced level steering stabilizer
2 Multi position handle bar mounting system for rider comfort or preference
3 Steering system turning radius very good with strong durable steering stops
4 Lower steering stem bearing designed for long life and race ready performance
5 Steering stem design sets a new bench mark for industry in strength & weight.
6 Upper steering stem bearing designed for low drag & sealed for long life.
7 Steering stem and handle bars proved strong under long term durability test
BRAKES
1 Front brakes by Magura are powerful 4 piston fixed caliper design.
2 Front rotors are a high quality self cleaning floating design
3 Front brake lines are steel braded for increased power & performance
4 Rear brakes by Magura are powerful single piston floating caliper design.
5 Rear brake rotor is of high quality with the self cleaning mud design.
6 The rear brake master cylinder and reservoir are all one light weight unit
7 The power, performance and Anti-fade of all the brakes is outstanding.
8 A very effective, lightweight parking brake system locks the front wheels
ENGINE
1 Engine- ready to race 4 stroke 525-53 hp or a 450-49 hp
2 Hydraulic clutch offers smooth consistent operation from start to finish.
3 Clutch cover designed into engine side cover for quick service of clutch
4 Engine uses one engine oil for gearbox and engine with no external oil tank
5 Side case on engine includes an engine oil site glass for quick oil level checks
6 Engine has two main oil filters, two bottom end strainers and a drain magnet
7 Valve adjustment is very easy in chassis, no shims or teardown needed.
8 Spark plug can be serviced with out any restrictions from fuel tank or plastic.
9 Radiator is state of the art with the correct capacity shape and installed angle
10 Cooling system is thermostatically controlled with a temp. controlled fan.
1 Radiator is state of the art with the correct capacity shape and installed angle
2 Cooling system is thermostatically controlled with a temp. controlled fan.
3 Magura Clutch system uses mineral based fluid in the system not brake fluid.
4 The clutch system performance and durability proved to be outstanding
CONTROLS
1 Hand levers are adjustable for front brake and clutch system free play.
2 Rear brake lever with bearing pivot is aluminum and fully adjustable.
3 Reverse lever is located so clutch and Rev are controlled by the same hand
4 Shifter is strong light weight aluminum with good grip
5 Parking brake system utilizes front brake master cylinder, no extra weight
6 Custom bend, strong light weight tapered handle bars ready for hand guards
FUEL, INTAKE, EXHAUST
1 Fuel tank with rider friendly design holds 3.7 gallons of fuel with reserve.
2 Carb. is a flat slide 39mm CR Keihin with a choke, hot start and spray pump
3 Carb. controls and adjustments like idle and jet changes offer easy access
4 Quick release seat and air box lid make a quick no tool air filter service
5 Air intake system is designed for mud and water prevention with snorkel
6 Air box is designed and ready for increased airflow under dry conditions
7 High performance light weight exhaust system with a sound decimal of 94
ELECTRICAL
1 Key and light panel includes a natural, reverse and oil press lamp
2 Combination switch pack nicely controls the starter and lighting functions
3 ATV is electric start in any gear including reverse with the clutch lever in
4 ATV has front and rear lights with a lever and pedal activated brake lamp
5 The engine is equipped with a 200w charging coil for extra light capacity.
6 Battery, starter, fuses and organized harness connector panel easy to access
7 CDI ignition can be set for high performance or full race with out tooling
8 Engine RPM is limited to 4000 in reverse limiting speed in rev to 11mph.
TRIM
1 Hood and plastic very easy to remove for service and adjustments
2 Rear plastic modular with air box and ready for air intake modification
3 Rear fenders have release or cut out ready for sand dune flag installation
4 Handle bars and controls are hand guard compatible for quick installation
5 Foot pegs are of race ready quality with nurf bar mounts included
6 Rear fenders designed for Hard Equipment mud extensions if needed
7 Front and rear bumpers are removable for replacement
8 Seat offers good traction and comfort for rider
9 Cable and wire guide on front of steering stem offers great organization
10 Sensational rider ergonomics designed with pro riders for pro riders.
SAFETY
1 Thumb throttle offers throttle limit screw and idle position switch
2 ATV is wired with a race ready tether switch to kill ignition if needed
3 Clutch lever starter interrupt switch prevent cranking or starting in gear
4 Heel guards are standard for heel and foot protection
5 Frame and foot pegs are ready for installation of competition nurf bars
6 Key needed for start up adds security to ATV
Geplaatst: zo 27 mei, 2007 18:05
door airwolf
se brutus ik wil nie ambetant doen maar hier is al een post van! :wink:
Geplaatst: zo 27 mei, 2007 18:38
door brutus32
airwolf schreef:se brutus ik wil nie ambetant doen maar hier is al een post van! :wink:
das nie ambetant ze :mrgreen:
d8 t ook maar vond die eerst nie :oops:
maar hier http://www.demodderberen.be/forum/viewt ... ht=ktm+525
staat geen techs of specs he :wink:
Geplaatst: zo 27 mei, 2007 18:49
door airwolf
daar heb je wel gelijk in! :wink:
Geplaatst: wo 06 jun, 2007 21:48
door coen
ik was vandaag gaan trainen in geldermalsen en daar waaren ze met de nieuwe ktm 525 quad aan het rijden testen met wp vering er op dat ding is echt super lelijk ik hoop dat de 450 model er beter uit ziet want dit is echt niks ingo ten vregelaar was hem aan het testen wp vering fotos maaken mocht niet en hij was helemaal afgeplakt
Geplaatst: wo 06 jun, 2007 22:07
door spoor!
je bedoeld de outlaw 500?
Geplaatst: wo 06 jun, 2007 22:17
door coen
nee de nieuwe ktm 525 xc uitvoering ik zeg tog niet dat ik een polaris heb gezien
Geplaatst: wo 06 jun, 2007 22:38
door tointjuh
hmm had ik toch beter even kunnen kijken. ik lag aan de trekker te sleutelen en genoot van het 4 takt geluid :p
Geplaatst: do 07 jun, 2007 07:26
door No Limit W-tec
coen schreef:ik was vandaag gaan trainen in geldermalsen en daar waaren ze met de nieuwe ktm 525 quad aan het rijden testen met wp vering er op dat ding is echt super lelijk ik hoop dat de 450 model er beter uit ziet want dit is echt niks ingo ten vregelaar was hem aan het testen wp vering fotos maaken mocht niet en hij was helemaal afgeplakt
Dan komt mijn redenering WP/Ohlins toch nog uit ?!
Geplaatst: do 07 jun, 2007 07:32
door Ralph
Toch WP. Daar zijn ze ongeveer een jaar geleden al mee bezig geweest bij WP, duurt lang :)
Geplaatst: do 07 jun, 2007 08:12
door coen
ik sprak daar iemand en die had hem vorige week ook al gezien en toen was de versnelings bak kapot gegaan er zit ook een achteruit op motor schijnt iets anders als de gewoone 525 te zijn
Geplaatst: do 07 jun, 2007 08:17
door Mika
Het zal wel dezelfde motor zijn als in de Polaris Outlaw zit, daar is ook de 6de versnelling vervangen door een achteruit en er zijn wat aanpassingen ivm de olie in het blok geloof ik.
Als hij eruit ziet als op de fotos kan het nog wel een mooie quad worden!
Geplaatst: do 07 jun, 2007 08:59
door No Limit W-tec
Ingo heeft idd getest, maar kan en mag er niet meer over zeggen...
Geplaatst: zo 10 jun, 2007 11:29
door tointjuh
Geplaatst: zo 10 jun, 2007 11:35
door RoBiN
Ziet er goed uit 8)
