Project Full Race YFZ 450 met +50 pk
Ludovic 250
wat was er gebeurd dan?Ralph schreef:Over een paar weken zal hij waarschijnlijk weer gaan rijden, het gaat nu steeds beter.
www.kicker.nl
car audio power
car audio power
In Belgium you can contact Quad Emotion, talk to Benoit, http://www.quademotion.ch/home.php
Shipping on a full set is around $125.00US.
Here are the different kind of shock we built with prices.
The ones we recommend for your application are in red.
They will offer a smoother ride; removing headshake and arm pump for a more comfortable
and faster ride, all shocks are ride height adjustable.
FRONT SUSPENSION
Pair fully adjustable (compression and rebound), in remote reservoir or piggyback reservoir:
Dual rate spring set up: $1040.00US
(300Ex, 250Ex, 250X, Banshee, Blaster, Warrior, LT250R, LT500)
Triple rate spring set up with self-sagging device: $1070.00US
(TRX450R, YFZ450, 400Ex, 250R, Z400, KFX400, Raptor, Cannibal, Blaze, KFX700 V-Force)
Long travel, Predator500 and DS650: Quadruple rate spring and self-sagging device: $1370.00US
(Long travel a-arms: Houser, Roll, Leager, Gipson, Herrmann Racing)
The triple & quad rate set up has a 600lbs/inch mid spring that eliminate bottoming out.
The First spring is a self-sagging device (zero-preload) that lowers the center of gravity by 2 inch.
Pair adjustable in compression only, in remote reservoir or piggyback reservoir:
Dual rate spring set up: $865.00US
Triple rate spring set up with self-sagging device: $895.00US
Long travel, Predator500 and DS650: Quadruple rate spring and self-sagging device: $1070.00US
If you are looking for maximum wheel travel, you should consider the compression only
shocks. They offer 3/4 inch more of shaft travel, so 2inches more of wheel travel, compared to
the fully adjustable (except for long travel and Z400, KFX400, Predator500 and DS650 these
set-up have the same amount of travel either compression only or compression and rebound)
We can build those shocks and send them to you in 3 weeks or less.
Recreational shock (emulsion, no reservoir)
Dual Rate: $515.00US
Triple rate spring set up with self-sagging device: $525.00US
(TRX450R, YFZ450, 400Ex, 250R, Z400, KFX400, Raptor, Cannibal, Blaze)
If you don’t want to pay for the compression adjustable shocks, go with these economic
shocks, they will give you a very good ride and they can be upgraded to remote reservoir,
compression adjustable at any time. These shocks offer the same feature and our built
with the same material of our racing shocks but without the reservoir.
All of our front & rear shocks comes with a shaft of 5/8inch for more resistance.
REAR SUSPENSION
“Most of our rear shocks offer more wheel travel than the stock units.
The Elka rebound adjustments doesn't affect the compression and vice-versa ”.
The rear shocks come's fully adjustable (compression and rebound) in a remote
reservoir.
Double rate rear shock with self-sagging device: $820.00 US
KFX400 linkage: $225.00US, offers 1 extra inch of wheel travel with the Elka rear shock.
All Elka shock absorber are custom built for the riders weight, quad geometry, his type of riding and type
of land he usually ride, this will give you maximum performance from your suspension.
All Elka shocks are fully rebuiltable so you can change the valving at any time, replace a
seal head easily or replace the shaft if needed.
Any new option we offer will fit on all shock.
Plus freight and any applicable taxes or custom charge if applicable
Call us at 1-800-557-0552 to pass your order or for any questions you may have.
-> Dus als je verder nog iets te vragen hebt, na zo'n complete uitleg
FRONT SUSPENSION
REAR SUSPENSION
reservoir.
Daan heeft iets aan zn staartbeen, ontsteking die maar niet weg wil gaan, geloof ik.bart schreef:wat was er gebeurd dan?Ralph schreef:Over een paar weken zal hij waarschijnlijk weer gaan rijden, het gaat nu steeds beter.
Street_Shee
Klopt inderdaad. 3 weken terug heb ik wat naar het lijkt m'n laatste ingreep gehad. Dus ik hoop met een week of 2 - 3 weer rond te crossen.Teunie schreef:Daan heeft iets aan zn staartbeen, ontsteking die maar niet weg wil gaan, geloof ik.bart schreef:wat was er gebeurd dan?Ralph schreef:Over een paar weken zal hij waarschijnlijk weer gaan rijden, het gaat nu steeds beter.
Daan
Rik350
welkom terug Daan je quad is er in elk geval klaar voor ondertussen als ik het goed begrijpStreet_Shee schreef:[Klopt inderdaad. 3 weken terug heb ik wat naar het lijkt m'n laatste ingreep gehad. Dus ik hoop met een week of 2 - 3 weer rond te crossen.
Street_Shee
ONZIN !!!!ALS HET IN 1 KEER GOED WAS GEWEEST HADDEN DIE JAPANNERS HET ER WEL ZELF OPGEZET.ronnieb schreef:airbox mischien niet maar de slang van de carb naar de box is zwaar klote
moet gewoon een rechte buis zijn met een heeeel klein knikje
PRECIES HETZELFDE ALS AL DIE DURE UITLATEN...............KLINKT HARDER IS NIET HETZELFDE ALS HARDER IN SNELLER.
STANDAARD RULES !
wie zet er nou een k&n op...........................................
