Is geen injectiemodule ! Die is apart verkrijgbaar maar net zo goed ook bij DynoJet en RapidBike. Voordeel is wel dat Yoshimura als leverancier van het fabrieksteam al veel langer test dan al de rest. Denk persoonlijk dat Yoshi beste injectiemodule gaat hebben, die mannen hebben daar heel wat ervaring in van bij de moto's.
Coaxial Relay Bypass Module (CRBM):
This unit is also known as the “Cherry Bomb” by Yoshimura. The Cherry Bomb is a simple plug in module that literally takes about two minutes to install. Along with recommended air box and exhaust modifications, the CRBM optimizes engine management parameters, maximizing engine performance. The net result in power equals out to be around seven H.P. with a open exhaust, airbox cover removed, and race gas. With a Yoshimura pipe there is an even greater performance gain. For closed course competition use only.
In addition to the basic CRBM unit, the full EMS system can be used. EMS can be purchased as a complete kit with all three units, or individually.
