Yamaha Racing kit voor YFZ450
No Limit W-tec
Bericht door No Limit W-tec »
http://www.yamaha-racingparts.com/model ... b=5&page=2
PISTON ASSEMBLY
New single-ring forged piston developed by YRRD for the YFZ450 for enhanced performance.
CYLINDER GASKET
Manufactured from a new material, this YRRD gasket is of a different thickness compared to the standard item.
INTAKE CAMSHAFT ASSEMBLY
Specially-developed YRRD intake camshaft with revised profile and timing for increased performance.
EXHAUST CAMSHAFT ASSEMBLY
CDI UNIT
The latest generation YRRD CDI unit benefits from revised mapping in order to maximise the performance gains of the new camshafts and exhaust system. Complete with bracket and fixings.
EXHAUST PIPE FRONT SECTION
Manufactured from lightweight titanium tube, this factory-replica exhaust pipe front section is designed to boost the YFZ450�s overall performance.
EXHAUST PIPE CENTRAL SECTION
Designed to increase overall performance, this titanium exhaust centre section saves weight and enhances power at all engine speeds. Includes bracket.
SILENCER
Specially developed titanium silencer meets 94 dB noise regulations and reduces overall weight.
RADIATOR CAP
Designed to keep your cooling system pressurised up to a maximum of 2.0 bar, this higher pressure radiator cap increases your YFZ450�s cooling efficiency for consistently high performance.
ENGINE OIL BREATHER (UNDER TESTING)
For greater engine efficiency during prolonged usage.
CRANKCASE COVER, CLUTCH
This machined factory crankcase clutch cover is the same as the design used by the YRRD MX-GP riders, and gives higher rigidity.
CARBURETTOR SETTING PARTS
Includes a range of needles and jets to enable you achieve the optimum set up in a range of conditions.
E/F BOLTS FITTING SET
Includes all the bolts, spacers, dampers, metal plug etc. required to fit the YRRD YFZ450 kit to your ATV.
YRRD YFZ450 ATV KIT MANUAL
This clearly written manual contains all the information you need to fit the YRRD kit to the YFZ450 ATV.
mx jake
Bericht door mx jake »
zal wel een aardige duit kosten een kompleet setje :shock:
airwolf
Bericht door airwolf »
denk ik ook maar vindt het wel schoon dempertjes!
No Limit W-tec
airwolf schreef:denk ik ook maar vindt het wel schoon dempertjes!
En 94 db !
airwolf
ja das wel een + punt
vermogen en weinig geluid!
ik zie nu juist dat zij ook gebruik maken van een powerbomb zoals fmf zou deze uitlaat misschien in samenwerking met fmf gemaakt zijn?
No Limit W-tec
Kit zit momenteel op een testquad van Yamaha, volledig voorzien van datalog instrumenten. Vanpevenage, Michels en Maessen zijn aan het testrijden vandaag in Loon met één doel : rijden tot het breekt. Ze zitten momenteel aan zowat 21 uur. Rijden in training is natuurlijk nog niet te vergelijken met rijden onder wedstrijdomstandigheden.
Zou wel eens goed kunnen dat kit ook onder de quad van Couprie komt voor Touquet.
Mika
Bericht door Mika »
Hoe staat zo'n 94db uitlaat t.o.v. de originele qua geluid (lawaai)? Op welk toerental is dat geluidsniveau berekent?
Blijkbaar bestaat ze nu enkel voor de YFZ. Komt er ook één voor andere modellen?
No Limit W-tec
Volgens FIM reglementen wordt db gemeten aan 4500 toeren.
Frankrijk doet echt inspanningen om geluid op trainingscircuits en wedstrijden naar beneden te halen en het werkt effectief. Iedereen houd zich er min of meer aan. Nogal wat anders dan de wedstrijden in België waar vaak meer dan 100 db de norm blijkt te zijn.
doubletracing
Bericht door doubletracing »
Zijn er al prijzen gekend van al dit moois?
www.depannagedoublet.be
No Limit W-tec
Geen idee, maar is te verkrijgen via elke Yamaha dealer, dus Christophe best eens bij Deliège langs gaan.
Dutje#82
Bericht door Dutje#82 »
heb richtprijs gekregen van de volledige kit, +3500€ :)
uitlaat appart kost zo'n 1200€ net als het cdi kastje
BERT'S RACING SHOP
No Limit W-tec
Slik !
Daar koop je een CRF motor voor die standaard even hard loopt en die betrouwbaarder is...
ICHE
Bericht door ICHE »
hola, lekker prijzig, ik had eerst gedacht aan een 2500 max. :shock:
quadrome
Bericht door quadrome »
dat is idd niet erg goedkoop :shock: :o
maarja waarom zou je 2 dempers moete hebbe?
Dutje#82
dat is'n extra demper, rinaldi maakt geen rommel hoor :wink: 1 voor zand en 1 voor harde parcours
een yfz of yz motor met rinaldi kit gaat harder of een standaard CRF geloof me vrij nikolas :duimhoog:
BERT'S RACING SHOP
