2014 Polaris Sportsman Ace
Moerasrijder
Bericht door Moerasrijder »
New for 2014
Key Features
Powerful 32 HP ProStar engine featuring dual overhead camshafts, a 4 valve cylinder head and electronic fuel injection (EFI) delivers excellent performance and fuel economy
Innovative, unique cab design offers a whole new off-road experience
Confident & Secure
On-Demand True All-Wheel Drive
Automatic transmission
Unique cab design
3-Point seatbelt
Easy attach side nets
Certified Roll Over Protection System (ROPS) cab frame
Assured stopping power with four-wheel/ four-disc braking system
Comfortable & Convenient
Bucket seat with 4" of adjustability
Easy ingress and egress with flat floor plan
Steering wheel offers 3.5" of adjustability for rider comfort
360 lb combined rack and storage capacity
1,500 lb towing capacity and high / low range transmission
Powerful 50 watt halogen lighting with high and low beams
Front rack opens to 2.8 gallons of semi-dry storage
Convenient access panel in cargo area opens to engine compartment for easy maintenance
Integrated foot rest
Easy To Ride
Independent dual a-arm rear suspension with 9.5" of suspension travel
MacPherson strut front suspension offers 8.2" of independent suspension travel
5.25 gallon fuel tank
Rider centric design
Compact & Nimble
Low-center of gravity for stable and responsive ride
10.25" ground clearance
32 HP ProStar Engine with Dual Overhead Cams and a 4 valve cylinder head
Lightweight Transmission for Efficient Power Transfer
Trail Compliant 48" Width
61.5" Wheelbase
2014 Sportsman Ace Specifications:
Engine
Engine Type: 4-Stroke DOHC Single Cylinder
Displacement: 327cc
Horsepower: 32HP
Fuel System: Electronic Fuel Injection
Cooling: Liquid
Drivetrain
Transmission/Final Drive: Automatic PVT P/R/N/L/H; Shaft
Drive System: On-Demand True AWD/2WD
Engine Braking System: N/A
Active Descent Control: N/A
Suspension
Front Suspension: MacPherson Strut With 8.2" (20.8 cm) Travel
Rear Suspension: Dual A-Arm, Anti-Sway Bar 9.5" (24 cm) Travel
Brakes
Front/Rear Brakes: 4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking Brake: Park in Transmission
Tires & Wheels
Front Tires: 25 x 8-12; 489
Rear Tires: 25 x 10-12; 489
Wheels: Stamped Steel
Dimensions & Capacities
Wheelbase: 61.5 inches
Dry Weight: 835 lb
Overall Vehicle Size (L x W x H): 90" x 48" x 68"
Ground Clearance: 10.25"
Seat Height: N/A
Fuel Capacity: 5.25 gallons
Front/Rear Rack or Box Capacity: 120 lb (55 kg)/240 lb (110 kg)
Payload Capacity: 575 lbs (261 kg)
Hitch Towing Rating: 1,500 lb
Hitch/Type: Standard/1.25" Receiver
Features
Cargo System: Lock & Ride
Lighting: Halogen, 55W low/ 60W high
Electronic Power Steering: N/A
Instrumentation: Digital Gauge, Analog Speedometer, Odometer, Tachometer, Tripmeter, Gear Indicator, Fuel Gauge, AWD Indicator, Hi-Temp/Low-Batt Lights, DC Outlet
Custom Package Options For Your Ultimate Riding Experience
Ultimate Trail Comfort
You will never want to step out of your machine with these Polaris® Engineered comfort-focused accessories. Cab-like components shield you from the elements while audio and mirrors give your ride a fun, premium feel.
Can am Renegade 500 2015
26" Maxxis Ceros op Machined Moose velgen
27" Maxxis Zilla op Stock Rims
BRP Radiator Relocator
Had
Yamaha Grizzly 550 2011
Mods:
- Wild Boar Rad Relocator
- 27" Maxxis Zilla's / 26" Maxxis Bighorns
- Bronco 2500 lbs Winch
- Moose front bumper
- RJWC exhaust
Moerasrijder
Re: 2014 Polaris Sportsman Ace
Had
Mods:
- RJWC exhaust
java
Bericht door java »
Denk dat dit de oudere generatie trekt.
Aan gezien het een kruising van een Quad en SBS is. Dus die altijd een quad hebben gereden en meer veiligheid willen
bkk
Bericht door bkk »
ramen en deuren erop en je zit warm en droog. maar voor wat dit ding gaat kosten heb je een een leuke personenauto, maar dat is natuurlijk niet zo leuk
Carlovdw
Bericht door Carlovdw »
7999$ dus valt het eigenlijk nog mee
YOLO
Yair
Bericht door Yair »
bkk schreef:ramen en deuren erop en je zit warm en droog. maar voor wat dit ding gaat kosten heb je een een leuke personenauto, maar dat is natuurlijk niet zo leuk
Dat is bij alle nieuw quads het geval.
Ik ben wel benieuwd hoe stabiel die is als je hard door de bocht heen gaat.
_____________________________
Ik vind het een goed idee. Denk eens aan de mindervaliden mensen die geen quad kunnen rijden. Die kunnen nu ook lekker rijden en offroad gaan
bizon450
Bericht door bizon450 »
Volgens mij gaat het niet zo aanslaan..
Denk dat je niet veel moeite moet doen om te kantelen, en als je een side by side neemt kan er tenminste nog iemand mee, maar vooral die motor .. Een 330cc enkel cilinder :?
Maar dit wilt natuurlijk niet zeggen dat het niet leuk is natuurlijk!
1) raptor 350 05 (verkocht)
2) raptor 350 05 (verkocht)
3) yfz 450 08 (verkocht)
5) banshee (weg )
6) blaster (verkocht)
7) trx 450 05 (verkocht)
8 ) yfz 450 05 (verkocht)
9) DS 450 xmx '08
10) r700 '12
Carlovdw
Ze hdd toch marktonderzoek gedaan en er zou nog ruimte zijn voor zo een product. Maar in Amerika zijn ze heel gek van dt buggy gebeuren denk ik, hier slaat het niet zo aan. Hier kan je toch ook bijna nergens off road
YOLO
